I found this great link: How do I resolve unmet dependencies after adding a PPA? but I can't seem to get any command involving apt-get to run correctly.
My main problem is a partition filling up and don't know why, so I'm trying to remove unneeded packages.
Ex:  apt-get purge aspell-en  returns:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 vim : Depends: vim-runtime (= 2:7.2.445+hg~cb94c42c0e1a-1) but it is not
going to be     installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages
(or specify a solution).
This message happens no matter which apt-get command I choose, including those meant to fix the problem in the first place!
To make matters worse, my disk is 100% full and I can't figure out how to fix.
When I run: apt-get -f install , it says:
Correcting dependencies... Done
The following extra packages will be installed:
      vim-runtime
The following NEW packages will be installed:
      vim-runtime
0 upgraded, 1 newly installed, 0 to remove and 228 not upgraded.
1 not fully installed or removed.
Need to get 6,207 kB of archives.
After this operation, 26.0 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://ftp.us.debian.org/debian/ squeeze/main vim-runtime all 2:7.2.445+hg~cb94c42c0e1a-1 [6,207 kB]
Fetched 6,207 kB in 1s (3,907 kB/s)
(Reading database ... 131282 files and directories currently installed.)
Unpacking vim-runtime (from .../vim-runtime_2%3a7.2.445+hg~cb94c42c0e1a-1_all.deb)
Adding 'diversion of /usr/share/vim/vim72/doc/help.txt to
/usr/share/vim/vim72/doc/help.txt.vim-tiny by vim-runtime'
dpkg-divert: rename involves overwriting
`/usr/share/vim/vim72/doc/help.txt.vim-tiny' with different file
`/usr/share/vim/vim72/doc/help.txt', not allowed
dpkg: error processing /var/cache/apt/archives/vim-
runtime_2%3a7.2.445+hg~cb94c42c0e1a-1_all.deb (--unpack):
subprocess new pre-installation script returned error exit status 2
configured to not write apport reports
No diversion 'diversion of /usr/share/vim/vim72/doc/help.txt by vim-runtime', none removed.
No diversion 'diversion of /usr/share/vim/vim72/doc/tags by vim-runtime', none   removed.
/var/cache/apt/archives/vim-runtime_2%3a7.2.445+hg~cb94c42c0e1a-1_all.deb
If I try to remove vim-runtime, I get:
Package vim-runtime is not installed, so not removed
 vim : Depends: vim-runtime (= 2:7.2.445+hg~cb94c42c0e1a-1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
First things first, try the command it's telling you to try:
apt-get -f install
To fix any broken packages. If your disk is full, this may or may not work depending on whether the broken package has been completely downloaded.
If the above doesn't work for lack of space, try
aptitude clean
to free up some space. Note, however, that this will clean your apt package cache (these are .deb files for the packages you installed; stored in /var/cache/apt/archives); the actual packages will remain installed, but you will no longer have the .deb files on disk and would need to re-download them if you purge/re-install an existing package.
Update
In response to your edited question, I think you need:
apt-get purge vim vim-runtime
apt-get install vim vim-runtime
Joseph R.
  • 320
