Before starting with my problem description, I would like to say that this is my very first time using Ubuntu or anything related to Linux!
Now my question!
I have installed the very last distribution of Ubuntu in my laptop (MSI FX620DX).
After a few updates I tried to install new applications such like Gparted or Synaptic... but it has been impossible to even get the package installed.
The same happens with any other application that I would like to install.
After launching the installation I get each time the same message:
*Package operation failed
The installation or removal of a software package failed.
installArchives() failed: (Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 158448 files and directories currently installed.)
Removing xserver-common-lts-raring ...
Removing 'diversion of /usr/lib/xorg/protocol.txt to /usr/lib/xorg/protocol-precise.txt by xserver-common-lts-raring'
dpkg-divert: error: rename involves overwriting `/usr/lib/xorg/protocol.txt' with
different file `/usr/lib/xorg/protocol-precise.txt', not allowed
dpkg: error processing xserver-common-lts-raring (--remove):
subprocess installed post-removal script returned error exit status 2
xserver-common-lts-raring*
I have tried several things that I found in different forums, but I could not find a solution for this.
Any idea or suggestion please?
Update: When I run the software updater,it says that only a partial upgrade is possible.
Then I get the following msg:
Could not install 'xserver-common-lts-raring'
Could not install the upgrades
The upgrade has aborted. Your system could be in an unusable state. A recovery will run now (dpkg --configure -a).
Any clue??
Update:
rs@rs-GE620-GE620DX-FX620DX-FX623:~$ sudo uname -a
[sudo] password for rs:
Linux rs-GE620-GE620DX-FX620DX-FX623 3.8.0-32-generic #47-Ubuntu SMP Tue Oct 1 22:35:23 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
rs@rs-GE620-GE620DX-FX620DX-FX623:~$ sudo lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 13.04
Release: 13.04
Codename: raring
rs@rs-GE620-GE620DX-FX620DX-FX623:~$ sudo dpkg -l | grep xserver-xorg-video-intel
ii xserver-xorg-video-intel 2:2.21.6-0ubuntu4.3 amd64 X.Org X server -- Intel i8xx, i9xx display driver
rc xserver-xorg-video-intel-lts-raring 2:2.21.6-0ubuntu4.1~precise1 amd64 X.Org X server -- Intel i8xx, i9xx display driver
