OK, so it seems this question has been asked before but not successfully answered. I have a Windows 8 Toshiba P75-A7200, and I've disabled Secure Boot, Fast Boot, and Fast Startup. Still, when I try to boot a Ubuntu 13.04 USB installer, I get to the GRUB screen and when I select "Try Ubuntu Before Installing," it hangs on a black screen. I had also tried booting in Legacy Mode, and it was the same.
The answers that I've seen haven't helped me, since they seem to assume I can access the Ubuntu terminal?
I've read this: My computer boots to a black screen, what options do I have to fix it? But disabling secure boot and enabling BIOS Legacy Mode didn't help. My computer doesn't have an UEFI/BIOS option; only UEFI or BIOS.
Same with this: Installing Ubuntu Alongside a Pre-Installed Windows with UEFI It suggests the same things, which don't work.
They both assume that I can get to the Ubuntu installer. I've also tried to install Linux Mint, and it was still unresponsive. I used 64bit for both, of course.
So Ubuntu is supposed to be able to work with UEFI and secure boot. What's going wrong?
PS It is a black screen, not a purple screen, so I don't think the problem is my video drivers, because I've had that happen on another computer. I know the problem is the UEFI, since I've installed Linux on three other Windows 7 computers just fine.
EDIT: dd just try to switch to nomodeset, and that took me to the ubuntu command line. I tried startx which resulted in an error, so I am lost on how to proceed?
Try these instead of nomodeset or in addition to nomodeset: acpi_osi=Linux acpi_backlight=vendor
Since you have a very new system, you may really need all the fixes that will be in 13.10 as both Kernel & Intel drivers have changes. But we only suggest 13.10 for those users who realize that is it not final, may crash and those bugs need to be reported so additionally fixes can be made. Or you are a tester not a user.
oldfred
  • 12,583
I solved the issue by installing the Ubuntu system in BIOS uefi-disabled mode, then reinstall in uefi mode the black screen issue was gone.
I'm adding a link to a post I made on coderwall after figuring it out, in case anyone is reading this who is having the same problems I was: https://coderwall.com/p/ydbldg
At the GRUB screen: You can either try Ubuntu or just install it, but before I did this I had to press 'e' and then revise the script. Before "quiet splash," I included "acpi _ osi=Linux acpi _ backlight=vendor". Then it should load without issue into the Ubuntu GUI.
While installing, if the installer doesn't recognize the existing Windows OS, you will have to select the "Something else" option and manually partition. In the end, Windows 8 will still be there, so don't worry. Select the partition you created and within it create a swap partition at about 10% of the size of the partition itself. The video I linked above explains this much better than I can. Then complete the installation.
If you try to reboot the computer and it loads onto a black screen again, don't fear. Restart the computer using the LiveCD and install boot-repair from the LiveCD:
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
sudo apt-get install boot-repair
In boot-repair, just click on the "Recommended" button. It will fix the GRUB screen so you can see Ubuntu and Windows, although Windows is named something weird in the menu, it still works. Restart the computer.
You should see the GRUB screen. Select Ubuntu and press 'e'. Repeat step 4 so you can get into Ubuntu. To fix the black screen problem permanently, edit this line in /etc/default/grub:
GRUB _ CMDLINE _ LINUX _ DEFAULT="acpi _ osi=Linux acpi _ backlight=vendor quiet splash"
Then in a terminal, do "sudo update-grub" and restart.
