when I try to apt-get update I'm getting the below error,
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
This just means that there is an application using apt.
First try to find out which application it is by using this command in the terminal
ps aux | grep '[a]pt'
If there is a process running using apt (like apt-get or aptitude), the best thing to do is just to let it finish what its doing. Otherwise you can kill it using
kill <PID of the process (2nd column in output of ps aux)>
After making sure there is no process or killing it, you can just remove the lock using
sudo rm /var/lib/apt/lists/lock
You can find out which process is using the file with fuser and optionally kill it:
sudo fuser -vik -TERM /var/lib/apt/lists/lock
try this commad : sudo fuser -vik -TERM /var/lib/apt/lists/lock
The fuser command is a Linux utility designed to find which process is using a given file, directory, or socket. It also provides information about the user owning running that process, and the type of access.
