I have created an Ubuntu VM on Azure, but I have some problem when I try to install a program. Command with sudo and without sudo:
ali@Azure:~$ sudo apt-get update
bash: sudo: command not found
ali@Azure:~$ apt-get update
W: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory
(1: Operation not permitted)
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
ali@Azure:~$
