Have been using 14.04 LTS for years with no problems. Have tried sudo apt-get update and get:
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
George Udosen
  • 37,534
alanb
  • 33
Panic over, all seems to be working fine after I closed down and restarted.
Do not know why this has happened.
alanb
  • 33
Usually your system or apt is doing some work behind the scenes so when you try to access the /var/lib[apt|dpkg] and the system has a lock on this location you get those errors.
Now to see who or what is holding that lock you can run:
sudo lslocks | grep -E "/var/lib/dpkg/lock"
George Udosen
  • 37,534
