12
I have a problem running Packet tracer 6.0.1 on Ubuntu 13.04.
I have a downloaded file from Cisco Netspace - this file had not extension. I added the extension tar.gz to this file and I could unpack it to a location with other folders and files, there was a file install too.
This was a .bin file and I used sudo chmod +x on this file and I used ./filename and installation has been launched I had to accept licence and so on.
After successfully installation I tried to launch Packet Tracer and nothing happened. Please help me, how can I correctly install and run Packet Tracer.
Note that I'm new in using Linux.
gertvdijk
  • 69,427
You probably did not follow the correct procedure. For one: nowhere does it state you need to rename the file to an extension that claims it is a compressed archive. This is one method that works:
  1. Re-download Cisco Packet Tracer 6.0 for Ubuntu.
  2. Open up Downloads folder, rename to CiscoPacketTracer6.0.
  3. Open terminal (Ctrl+Alt+t).
  4. Type in:
    sudo su
    And type in your password and press Enter.
  5. Then type:
    cd Downloads
    ls
    chmod +x CiscoPacketTracer6.0
    ./CiscoPacketTracer6.0
  6. Next, click the space bar to go to the bottom (You'll see a % at the bottom left of terminal) of the EULA and press the y button to accept the terms and conditions. After that, sit back and wait until it's done.
  7. Next, click on Ubuntu symbol and search "Packet" on your computer. You should see the Cisco Packet Tracer 6.0 icon. Right mouse click on that and packet tracer should open.
If this does not work please edit your answer and PM me.
The installer puts its files into:
/usr/local/PacketTracer6/
The executable is:
/usr/local/PacketTracer6/bin/PacketTracer6
So you can also create a link in /usr/local/bin to be able to run from the command-line:
sudo ln -s /usr/local/PacketTracer6/bin/PacketTracer6 /usr/local/bin/
Finally, for reference, to find the path and arguments used when a program was run from the gui, you can use: ps auxfwww | less.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
This is how I installed Packet Tracer 6.0.1 on Ubuntu 13.10:
Downloaded "Cisco Packet Tracer 6.0.1 for Linux - Ubuntu installation (no tutorials)" from the cisco's www.netacad.com website.
Yes, it doesn't have an extension.
I made a copy of it and renamed PT601.tar.gz
I chose a short name just for ease of use and the extension should be .tar.gz.
Open a terminal (Ctrl+Alt+t)
cd "location of the PT601.tar.gz"
For example:
cd /home/Downloads
sudo chmod a+x PT601.tar.gz
bash ./PT601.tar.gz
It took me a few days being beginner on Linux, and Cisco didn't give any instructions.
Hopefully this will help a few people getting by with Packet Tracer 6.0.1 on Ubuntu 13.10.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
elemer82
  • 491
As you have downloaded Cisco Packet Tracer 6.0.1 for Linux, don't change its extension but change its name to use commands easily, let's say you have changed it's name to xxx.bin and its under home directory-
Press Ctrl+Alt+t to open a terminal and then change the permission for that file by using the following command:
chmod +x xxx.bin
and run
./xxx.bin
and after that press spacebar, and then y for yes and provide your password.
If you are using 64 bit System Architecture, you have to install ia32-libs by running:
sudo apt-get install ia32-libs-gtk
If you are not sure about the Architecture use:
arch
or
uname -m
The downloaded file would be of approximately 77Mbs. Check it's correct size before initiating the procedure.
Sukupa91
  • 3,067
