I have installed smoothly PTR 6.0.1 according to this site (How do I run Cisco Packet Tracer 6.0.1?), but when I want to run it this error appears:
PacketTracer6: error while loading shared libraries: libQtScriptTools.so.4: cannot open shared object file: No such file or directory
I have Ubuntu version 13.10. Can somebody help me with this? Thanx.
EDIT: Hello, so I have installed this libqt4-scriptools:i386 library and now this error appears:
PacketTracer6: error while loading shared libraries: libQt3Support.so.4: cannot open shared object file: No such file or directory.
I find this library here:/usr/local/PacketTracer6/lib/libQt3Support.so.4
user224327
  • 33
PacketTracer6 tries to load a library called libQtScriptTools.so.4, but cannot find it. This usually is caused by one of two things.
Library missing
The first, more likely cause: The library is not installed. Luckily, the fix is easy.
Run
sudo apt-get install libqt4-scripttools:i386
That will install the 32-bit-version of the library, which is necessary because Cisco ships a 32-bit version of PacketTracer6 only.
Problems with the library path
The second cause: The library is installed, but PacketTracer cannot find it. In order to work around that, you could run
LD_PRELOAD=/path/to/libQtScriptTools.so.4 /path/to/packettracer
after replacing the paths with the real ones from your system.
Update: Since PacketTracer also seems to need libQt3Support.so.4, but doesn't use the version it ships with, you will have to install libqt4-qt3support:i386 as well.
drc
  • 2,890
  • 15
  • 16
The following lines of code can be found in the inside the "install" file.
sudo apt-get -y install lib32z1
sudo apt-get -y install lib32ncurses5
sudo apt-get -y install lib32bz2-1.0
sudo apt-get -y install libgcc1:i386
sudo apt-get -y install libstdc++6:i386
sudo apt-get -y install libssl-dev:i386
sudo apt-get -y install libqtwebkit4:i386
sudo apt-get -y install libqt4-scripttools:i386
Once the above packages are installed you should be able to run the application.
Note: lib32bz2-1.0 failed to install on Ubuntu 15.04 and the application still seams to run just fine.
BvL
  • 46
