When I plug my FiiO E7 USB Audio DAC & Amp in Ubuntu 13.04, it is recognized as Audio DAC but only via the Analog Output port.
I have to log-out and in again before the USB Audio DAC Digital Output (S/PDIF) comes available in Sound settings, which has much better quality.
How can I enable the Digital Output manually, so I don't have to logout?
landroni
  • 6,011
Janghou
  • 6,035
To enable digital output on a FiiO X3 without ending session you need to kill PulseAudio as suggested in How to I get the right Pulseaudio profiles to show up without restarting Pulseaudio?:
pulseaudio -k
Then I can see the device FiiO USB Audio Class 2.0 DAC Digital Stereo (IEC958), while PulseAudio Mixer reports the Digital Output (S/PDIF) port.
I'm not convinced yet that using the Digital Output (vs the Analog Output) changes audio quality that much, though... And the X3 still displays 48kHz/24bits, whichever device is selected, so I suspect that the OS still downsamples the whole thing before passing it to the device...
landroni
  • 6,011
You need to connect your E07 before you turn on your computer. It is that easy. Enable Digital Output for E07 in Ubuntu
