  • I go to Tools -> Options -> Personalization.
  • I check 'Own Theme' then click on 'Select Theme'.
  • I found the theme I wanted, copied and pasted the URL in the "Select Theme' window.
When I click 'OK' LibreOffice crashes. I even tried looking in this folder: /home/jason/.mozilla/firefox/3yvxv88p.default/lwtheme to copy and paste the images into the LibreOffice gallery but the images for my current theme are not there.
I have images from a previous theme which are also in the LibreOffice gallery. I can't seem to get personas to work in LibreOffice 4.1.0.4. Any thoughts or suggestions?
I am running Xubuntu 12.04 64-bit.
Simon
  • 4,843
This may be a bug and you should report it. You may still be able to install the personas manually.
tstew
  • 328
This problem appears to be a bug that affects some systems.
Apparently, you can still install 'personas' manually, but the ability to add 'personas' from the menus is malfunctioning.
Source: http://ask.libreoffice.org/en/question/21421/cant-use-personas-in-lo-4104/?answer=21431#post-id-21431
carnendil
  • 5,529
Found the solution. As it turned out I had files and folders still left on my system from LibO 3 and an earlier version of 4.1. I downloaded and installed the pre-release 4.1.1.1, uninstalled/deleted the old files and personas are working for me now.
