sorry for my english Due to malfunctioning of my router, I downloaded Libreoffice for Linux(LibreOffice_4.1.0_Linux_x86-64_deb.tar.gz) on a macintosh iBook G4, then copied the file ......-.tar.gz., by a memory stick, on a PC where I had just installed successfully XUbuntu-13.14 (same way: downloaded on mac and trasferred on PC for installing, was OK).
Double.click on the file for installing and I had this message (in Italian): "Sequenza byte invalid nell'input di conversione" I presume came from English "Invalid byte sequence in conversion input". But what does it means?
I supposed corrupted data. I downloaded (in the same way, because in that moment I can not change my router) the file again. The result was the same. Thinking due to a wrong version I downloaded other version:
LibreOffice_4.1.0_Linux_x86_deb.tar.gz and LibreOffice_4.1.0_Linux_x86-64_rpm.tar.gz
Always the same
Help me please
Biagio
biagio
The first time it failed was maybe due to corruption of data, but the second time, you downloaded the wrong file type. Download this file from libreoffice.org. After copying to your Xubuntu PC, extract the file. You will get a .deb file. Double click it to install
cshubhamrao
  • 4,285
  • 30
You can install LibreOffice 4.1 with the PPA: https://launchpad.net/~libreoffice/+archive/ppa
Instructions for using the PPA: What are PPAs and how do I use them?
ignis
  • 4,247
