Summary: enter button unavailable when choosing OS (either ubuntu or windows7)
Today I have installed ubuntu 13.04 alongside windows7. When BIOS asks which OS to run I am unable to select other than the default - which is selected after 10s timeout. (if I use the arrow keys the timeout no longer counts down).
I changed the default OS that boots after grub-timeout to my regular windows 7... as described here:
How do I set the grub timeout and the grub default boot entry?.
However I'm wondering if there's any way I can select ubuntu by other than with the 'enter' button. This button happens to be the ONLY button that is not working and I have to plug in another keyboard via USB.
NOTE: On windows I have mapped another key to act as the 'enter' button, and hoping to do the same within ubuntu - if you are able to help me there as well, it would be appreciated but not my main concern.
If you can help me as to what I could possibly do, I give you 5 hundred PROPS :D
You can always use the Left Arrow key. I just tested it one of on my Ubuntu machines, and it worked like a charm, without me even needing to configure or change anything.enter image description here
EDIT: I meant the Right Arrow, not the left one.
TSJNachos117
  • 1,532
  • 16
  • 20
