When installing wine1.6 and wine1.6-amd64 from ppa:ubuntu-wine on Kubuntu 12.10 (quantal), it always asked me for installing wine1.6-i386
root@ezgo64:/etc/apt/sources.list.d# LC_ALL=C apt-get install wine1.6
Reading package lists... Done
Building dependency tree
 wine1.6 : Depends: wine1.6-i386 (= 1.6-0ubuntu1~ppa1) but it is not installable
           Recommends: ttf-mscorefonts-installer but it is not installable
           Recommends: fonts-horai-umefont but it is not going to be installed
           Recommends: fonts-unfonts-core but it is not going to be installed
           Recommends: winbind but it is not going to be installed
root@ezgo64:/etc/apt/sources.list.d# LC_ALL=C apt-get install wine1.6 wine1.6-amd64
However, how could I install wine1.6-i386 on a amd64 box? Therefore I need to download the package, extract it and change the dependency to remove wine1.6-i386 so that I can install this amd64 version of wine1.6.
wine1.5 has the same problem.
Any suggestions?
new information added: Thanks for suggestions. However when I tried to install wine1.6-i386, it asked for a lot of other i386 packages like libgstreamer0.10-0:i386. I was not able to install it and didn't know how to solve such dependencies. Any help will be appreciated.
I found the answer... at least a solution.
Can't install wine (or ia32-libs) in Ubuntu 12.10 64 bit
Using /etc/apt/preferences to assign Pin-Priority would solve the dependencies problems while installing wine-i386. However, in some of my machines it would remove almost all kde packages and I need to re-install them back after installing i386 packages.
Just add additional architecture:
sudo dpkg --add-architecture i386
update your apt sources and it should work.
Example (as root):
dpkg --add-architecture i386 # Add i386 architecture for Wine
add-apt-repository -y ppa:ubuntu-wine/ppa  # Add PPA/Wine repository
apt-get update
apt-get install -qy wine1.8
See also: Can't install wine (or ia32-libs) in Ubuntu 12.10 64 bit
kenorb
  • 10,944
The wine1.x metapackage depends on both wine1.x-amd64 and wine1.x-i386 actual packages. These correspond to support for amd64 and i386 windows applications. 64 bit systems can still run 32 bit binaries providing they have 32 bit versions of all the necessary libraries.
You can install only the wine1.x-amd64 package to avoid the multiarch dependency, but you will then not be able to load 32-bit windows applications, which still seems to cover a significant fraction of games and applications.
I'm not sure about the dependency problems, but I would look for general fixing broken package answers rather than anything wine-specific.
chronitis
  • 12,647
