I have followed the below procedures to install wine in Ubuntu 14.04 LTS:
add-apt-repository ppa:ubuntu-wine/ppa
apt-get update
apt-get install -y wine
However, I see the below error messages:
unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
wine : Depends: wine1.6 but it is not going to be installed or
wine1.8 but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
After I did a check on the system, unity-control-center has already been installed. And I encounter the same error message when trying to install wine1.6.
Any help will be appreciated!
Thanks!
updated
According to A.B.'s suggestions, these are the outputs:
lsb_release -a
LSB Version: core-2.0-amd64:core-2.0-noarch:core-3.0-amd64:core- 3.0-noarch:core-3.1-amd64:core-3.1-noarch:core-3.2-amd64:core-3.2-noarch:core-4.0-amd64:core-4.0-noarch:core-4.1-amd64:core-4.1-noarch:security-4.0-amd64:security-4.0-noarch:security-4.1-amd64:security-4.1-noarch
Distributor ID: Ubuntu
Description: Ubuntu 14.04.3 LTS
Release: 14.04
Codename: trusty
uname -a
Linux yiliang-PORTEGE-Z930 3.19.0-43-generic #49~14.04.1-Ubuntu SMP Thu Dec 31 15:44:49 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
apt-get install libcheese-gtk23 libcheese7
Reading package lists... Done
Building dependency tree
libcheese-gtk23 is already the newest version.
libcheese7 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
apt-get install wine1.8
wine1.8 : Depends: wine1.8-i386 (= 1:1.8.0-0ubuntu1)
The output of
apt-cache policy wine wine1.6 wine 1.8 unity-control-center libcheese-gtk23 libcheese7
is very long and can be accessed from here.
wine:
Installed: (none)
Candidate: 1:1.8.0-0ubuntu1
Version table:
1:1.8.0-0ubuntu1 0
500 http://ppa.launchpad.net/ubuntu-wine/ppa/ubuntu/ trusty/main amd64 Packages
1:1.6.2-0ubuntu4 0
500 http://sg.archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
wine1.6:
Installed: (none)
Candidate: 1:1.6.2-0ubuntu4
Version table:
1:1.6.2-0ubuntu4 0
wine1.8:
Installed: (none)
Version table:
1:1.8.0-0ubuntu1 0
unity-control-center:
Installed: 14.04.3+14.04.20150916-0ubuntu1
Candidate: 14.04.3+14.04.20150916-0ubuntu1
Version table:
*** 14.04.3+14.04.20150916-0ubuntu1 0
500 http://sg.archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
100 /var/lib/dpkg/status
14.04.3+14.04.20140410-0ubuntu1 0
500 http://sg.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
libcheese-gtk23:
Installed: 3.10.2-0ubuntu2
Candidate: 3.10.2-0ubuntu2
Version table:
*** 3.10.2-0ubuntu2 0
libcheese7:
Version table:
wine1.8-i386:
Installed: (none)
Candidate: (none)
Version table:
