I have files ending in ~ in my home directory, and I want to delete them. How do I do that? How do I prevent this backup functionality?
Jorge Castro
  • 73,717
Flair
  • 517
If you also have unwanted backup files in subfolders, it gets a bit more difficult:
find . -type f -name '*~' -delete
IQAndreas
  • 3,298
You can simply run rm *~ if you're sure there is no other file that you need which ends in ~
If it is gedit that is creating the backup files, you can open gedit and select Edit->Preferences->Editor and uncheck the option "Create a backup copy of files before saving"
And for nano, look in /etc/nanorc for:
## Backup files to filename~.
set backup
and change that to
# set backup
rahules
  • 382
-2
The hidden files are in place to keep user program setup and other program information.
I strongly suggest you to not delete those files.
If you a sure to want to delete them, then open the menu Places->Home Folder (press CTRL+H if you don't see hidden files) and then select and press the Delete keyboard key. If you don't want move them into trash press Shift+Delete keyboard keys
From terminal you can delete hidden files ( don't do it ) with: rm -fr /home/youruser/.*
Nick
  • 228
