For example consider that i have created a file temp.txt and delete it later, there is still an invisible file temp.txt~ Of course I can delete it but Why do i need to do it always, So how to avoid it..
Asked
Active
Viewed 64 times
The file with tilde is called backup file and made everytime you edited a file on an editor. If you want, you can recover the file from that backup. Otherwise, delete it also.
Erkin Alp Güney
- 498
If you don't want it, open Gedit and go to Edit->Preferences->Editor and uncheck Create Backup Copy if it's checked.
Also you can open terminal and navigate to that dir then
rm *.ext~
Zuko
- 1,277
