230
apt-get has a few options which looks the same to me: autoclean, autoremove and clean. What do each of them do?
Braiam
  • 69,112
Antony
  • 3,185
From the apt-get man page:
  • clean: clean clears out the local repository of retrieved package files. It removes everything but the lock file from /var/cache/apt/archives/ and /var/cache/apt/archives/partial/. When APT is used as a dselect(1) method, clean is run automatically. Those who do not use dselect will likely want to run apt-get clean from time to time to free up disk space.
  • autoclean: Like clean, autoclean clears out the local repository of retrieved package files. The difference is that it only removes package files that can no longer be downloaded, and are largely useless. This allows a cache to be maintained over a long period without it growing out of control. The configuration option APT::Clean-Installed will prevent installed packages from being erased if it is set to off.
  • autoremove: is used to remove packages that were automatically installed to satisfy dependencies for some package and that are no longer needed.
Every command has a manual page, if you want to know what their parameters are or what each of them do, just type in the shell `man ` Ex. `man apt-get`
Antony
  • 3,185
Decio Lira
  • 8,154
59
autoclean: removes all stored archives in your cache for packages that can not be downloaded anymore (thus packages that are no longer in the repo or that have a newer version in the repo).
clean: removes all stored archives in your cache.
autoremove: a whole different thing, this option makes apt look for packages that are installed as dependency of an already uninstalled package and removes them. This is used to clean up unused dependencies that remain on your system.
Answer found: http://ubuntuforums.org/showthread.php?t=394952
Antony
  • 3,185
