For example, de-fragmenting, disc cleanup, or stuff like that?
Not really. There is no need to defrag the disks, because they don't get fragmented unless you have like 99% of the disk full. There is no need for a cleanup, unless you are really low on space. Performance is not an issue, like in Windows. There is also no need to cleanup the registry, because Ubuntu doesn't have one.
However, some applications might need maintenance. For instance, Firefox databases might become bloated with time, so you need to vacuum them to keep the performance high. Any application that uses SQLite files can suffer from the same issue.
If you want to do cleanup, see CCleaner equivalent?.
What I do to avoid wasting space is to always cleanup the apt cache. This is what I use when upgrading packages:
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade
sudo apt-get autoremove
The first command cleanup the cache, the second update the software sources, the third upgrades necessary packages and the last one uninstall unnecessary software.
- 6,427
You want to make regular backups of all important documents, that's the most important "regular maintenance" task there is. But of course you're already doing this... ;-)
Furthermore, you can use applications like Computer Janitor to clean up unneeded libraries, old kernels, etc.
In most cases fragmentation is not really a big issue, and in any case it won't harm you as much as it did in the old days. The files that are most likely to get fragmented are probably log files (which really isn't all that important; if you need them microseconds are not what you care about) and more in general when small chunks of data get written to several files in parallel. I wouldn't worry about this though, as long as you don't see filesystem performance degrade badly (my main desktop was installed in 2007 and upgraded ever since, and I don't see any performance issues, even if at some times both partitions have been quite full).
- 19,802
While you don't have to do regular cleanups, there may be times you want to cleanup unnecessary stuff to make some more disk space and lighten the system.
Check Cleaning up a Ubuntu GNU/Linux system at UbuntuGeek.
Update: also How do I free up disk space? here (as DrKenobi refers).
If you use firefox, there are addons like Vacuum Places Improved to optimize database.
I also prefer creating a tmpfs point for the entire firefox profile -- but that would be a matter of personal preference. As an additional advantage, this helps me maintain a profile backup -- just in case.
For a typical Ubuntu user, here is what you can do :
use the Computer Janitor (System > Administration) to cleanup old packages and alluse theapt-getcommand line tool to cleanup up unused packages- the Trash (bottom right corner of the screen) to cleanup deleted files
- manual maintenance of your home (/home/~username) directory
Other than that, you don't need to defragment your hard drive, really. As for spywares and all, I never had any problem so far (for a typical user).
- 2,494
Nope, the nature of (and, a bit, obscurity of) Linux means defragmenting, registries, and viruses are not an issue. However, Linux does accumulate a bit of useless data which doesn't slow your computer down but does take up hard drive space (an issue if you're using an SSD). This is easy enough to fix - you can run 'apt-get autoremove' in a terminal to remove unneeded packages, and/or install Ubuntu Tweak from the software center or terminal:
sudo apt-get install ubuntu-tweak
which is generally a great tool to have under your belt anyways. It has a janitor feature that can automatically detect and, when selected, clean up your old kernels, unneeded packages, browser caches, and more.
- 1,508
- 6
- 16
- 29
