While trying running the command apt upgrade. It shows the list of package that are no longer required.
xyz@abc ~ # apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
android-libunwind crda guile-2.2-libs libdav1d5 libdav1d5:i386
libdns-export1110 libgit2-1.1 libgsasl7 libicu67:i386 libirs-export161
libisc-export1105 libisccfg-export163 libjim0.79 libjs-highlight.js
libjs-is-typedarray libjs-typedarray-to-buffer libjs-uglify libllvm13:i386
libmailutils8 libnode72 libopts25 libpython3.9 libpython3.9-dev
libssl1.1:i386 libtexlua53 lsp-plugins-jack node-array-union node-array-uniq
node-execa node-is-typedarray node-merge-stream node-mimic-fn
node-stealthy-require node-strip-eof node-typedarray-to-buffer ntp
ntpsec-ntpdig pigz python3-ldb python3-talloc python3.9-dev ruby-uglifier
sntp
Use 'apt autoremove' to remove them.
The following NEW packages will be installed:
android-libboringssl android-libsparse cron-daemon-common dh-dkms
gir1.2-ayatanaappindicator3-0.1 isympy-commo
But when I try to remove them using apt autoremove. It doesn't remove any anything.
xyz@abc ~ # apt autoremove
0 upgraded, 0 newly installed, 0 to remove and 1558 not upgraded.
I'm trying to understand why this is happening.
Ideally, if there is no dependency on the packages, apt autoremove should remove those packages.
