13
I'm trying to install nodejs and npm, however, it fails. This is my terminal:
sudo apt-get install nodejs npm
Reading package lists... Done
Building dependency tree
nodejs : Conflicts: npm
What to do? I'm kinda lost :(
Just execute this commands!
Installing Node.js via :
sudo apt-get install -y python-software-properties python g++ make
sudo add-apt-repository ppa:chris-lea/node.js
sudo apt-get update
Check version:
$ npm -v
1.4.9
$ node -v
v0.10.28
For more info visit this guide.
Sounds like you have one of the nodejs PPAs installed. One I use has npm distributed as part of the nodejs package and it's impossible and unneccessary to install both.
Install nodejs and see if you can run npm.
Oli
  • 299,380
You should follow the Node.js guide
curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
sudo apt-get install -y nodejs
barbolo
  • 213
