sudo apt-get install npm
then I get this:
npm : Depends: nodejs but it is not going to be installed
Depends: node-abbrev (>= 1.0.4) but it is not going to be installed
Depends: node-ansi but it is not going to be installed
Depends: node-archy but it is not going to be installed
even tough nodejs exists on the system, should I install separately each dependency how can I install them in one bunch?
also I've tried this:
sudo apt-get install nodejs-dev
and I get this:
nodejs-dev : Depends: nodejs (= 0.10.25~dfsg2-2ubuntu1) but it is not going to be installed
why it say's that nodejs doesn't exist, if it is on the system already installed?, if its broken how could I fix it? I've tried to remove it and install again, but didn't helped, any ideas?
EDIT
npm:
Installed: (none)
Candidate: 1.3.10~dfsg-1
Version table:
1.3.10~dfsg-1 0
500 http://kg.archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
100 /var/lib/dpkg/status
nodejs:
Installed: 4.2.1-2nodesource1~trusty1
Candidate: 4.2.1-2nodesource1~trusty1
Version table:
*** 4.2.1-2nodesource1~trusty1 0
500 https://deb.nodesource.com/node_4.x/ trusty/main amd64 Packages
0.10.25~dfsg2-2ubuntu1 0
node-abbrev:
Installed: 1.0.4-2
Candidate: 1.0.4-2
Version table:
*** 1.0.4-2 0
node-ansi:
Installed: 0.2.1-1
Candidate: 0.2.1-1
Version table:
*** 0.2.1-1 0
node-archy:
Installed: 0.0.2-1
Candidate: 0.0.2-1
Version table:
*** 0.0.2-1 0
