After installing node.js I execute this command:
sudo apt-get install npm
And getting error:
npm : Depends: node-gyp (>= 0.10.9) but it is not going to be installed
$ sudo apt-get upgrade -f npm node-gyp
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
nodejs-dev : Depends: libssl-dev (>= 1.0.0g) but it is not going to be installed
E: Broken packages
