I have an HP laptop with 2 partitions: C: and D:, with windows 7 installed in the C: drive and D: is the Recovery partition.
When I try to install Ubuntu 12.04 LTS using Wubi, it only shows the C: drive for installing and not the D: drive where I wanted to format and install ubuntu.
So, if I go ahead and install in the C: drive where windows 7 is already installed, would Wubi erase windows 7? Or it will just install Ubuntu as a program in windows?
bcbc
  • 6,036
No, wubi runs under windows. So it won't remove the host OS.
It is like running virtual system.
Know more - https://wiki.ubuntu.com/WubiGuide
Web-E
  • 21,716
or it will just install ubuntu as a program in windows??
Indeed. Wubi will install it as a program in Windows. This will make Ubuntu slower and dependent on Windows.
If you don't want to install as a program in Windows, you should follow these instructions.
jobukkit
  • 5,266
