Will all XP files be deleted? I'm new to Ubuntu and all I want to know is if those files of XP won't get lost at all.
Uwe Plonus
  • 709
  • 14
Lucas
No, not with Wubi.
what happens with the XP files, i want to know that.
Nothing. Wubi is designed to try Ubuntu out without fiddling with your hard drive partition, and yet do have it permanently installed. It fills the gap between a "real" install and the non-persistent Live disc image.
With Wubi you use an installer inside Windows (.exe file), so there's no way to use the regular partitioner, I believe. Instead, it will be installed in a file (root.disk if I'm correct) on the NTFS drive of your Windows OS.
So, basically, only some files will be added and the Windows bootloader will be configured to have an entry to boot into Ubuntu, installed in the root.disk file.
gertvdijk
  • 69,427
