I installed Ubuntu 12.04 on my partitioned hard disc:
/dev/sda
/dev/sda1   ntfs   Windows
/dev/sda2   ntfs   Backup Disk
/dev/sda3   ext4   Ubuntu 12.04
I can boot from Ubuntu and Windows via Grub. Now, I decided to remove the Ubuntu since I'm always stuck with getting the driver to work properly on my Radeon HD 7770 (always causing boot failure). I cannot find ways to uninstall it (there is an option in the installer where Remove Ubuntu 12.04 and reinstall it but that does suits), so I decided to delete the Ubuntu partition in /dev/sda3 thinking it would solve the problem.
However, when I restarted my desktop the GRUB (purple background) still shows the Ubuntu, Memory Test, Windows (loader). I want to remove this so that my desktop will boot directly from Windows.
Defensor
  • 360
You can the steps from this link:
Removing GRUB from windows system after uninstalling Ubuntu from Windows 7
You can also see http://www.sevenforums.com/installation-setup/62209-remove-grub-restore-windows-7-a.html
You can create a system repair disc in windows 7.Use that disc to boot. You can also launch recovery options by pressing F8 repeatedly before the windows boot logo appears.
M.Tarun
  • 5,121
