I have installed Ubuntu alongside Windows 7 (no separate partitions, I selected inside windows option).
I want to uninstall Ubuntu but last time I tried it and the Ubuntu is released but the GRUB remains. How do I remove GRUB?
You need Windows 7 installation disk, boot it, choose repair option when you are asked to menu.
It will check automatically for start up problems. Let it check it.
command prompt.In cmd you have to type just two following commands and grub will be removed.
bootrec /fixmbr
bootrec /fixboot
Close cmd and restart your machine.
Here's how.
Choose Language & HELP :-)) entry.Windows entry.Fix Boot of Windows entry.No more Grub! :)
Put windows 7 disk and boot from it.
Choose to repair windows now.
It will ask to repair, select yes. After restart if grub is still there, follow above step.
Select windows partition found by the recovery manager and click Next
Now choose startup repair.
This internally uses command fixboot and fixmbr. You can google for more details.
