-1
New computer with Windows 7 installed, I defrag, shrink, re-boot from Ubuntu LiveUSB, go to gparted and look at partitions before installing Ubuntu....for some reason Win7 is still taking up 400G of my HD!
I resized partition down with gparted, exit and yes of course I can't boot into Windows.
When I go to install Ubuntu in new large unallocated space I get a blank screen at the point you are asked what kind of installation you want.
I have Ubuntu 12.04 LiveUSB, Windows 7 re-installation disk and driver disks also. The HDD currently has 3 allocated partitions: 'diag' fat16, 'recovery' ntfs and 'OS' ntfs which has a red '!' next to it.
Lucio
  • 19,191
  • 32
  • 112
  • 191
razzrat
You should delete all your partitions and make two big partitions (or whatever you want to). One partition for Windows and another one for Linux. If you want to, create a 3ยบ partition to save your personal files with a NTFS format (compatible with both platforms).
After resize your partitions, install Windows first. And then install Ubuntu.
If you want to try to recover some file, take a look at this post
If you have a black screen after the installation, follow the steps mentioned here
If you're still facing troubles, the most probably is that your HDD is damage.
That is all that I can tell you. Hopefully, this will be useful.
Lucio
  • 19,191
  • 32
  • 112
  • 191
