11
In installed python-virtualenv, because this question said I should use virtualenv to install pygame. However, I'm not really sure how that's accomplished.
What I did (following these instructions):
virtualenv --no-site-packages --distribute -p /usr/bin/python3.3 ~/.virtualenvs/pywork3 --no-pip
And then I don't know where to go.
How do I install pygame to be used in the virtualenv?
Edit: I followed GuySoft's instructions, and everything installed great. However, when I tried import pygame in python3, I got the following error:
>>> import pygame
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/home/alden/.virtualenvs/pywork3/lib/python3.3/site-packages/pygame/__init__.py", line 95, in <module>
from pygame.base import *
ImportError: /home/alden/.virtualenvs/pywork3/lib/python3.3/site-packages/pygame/base.cpython-33m.so: undefined symbol: PyCObject_Check
ananaso
  • 4,080
  • 32
  • 52
I suggest you have pip in your virualenv, its useful.
Note: must have pygame's dependencies installed, you can find out what they are and install them with:
sudo apt-get build-dep python-pygame
Then try this:
rm -rf ~/.virtualenvs/pywork3 #clean what you have there
mkdir -p ~/.virtualenvs/pywork3
. ~/.virtualenvs/pywork3/bin/activate
pip install pygame
GuySoft
  • 784
that is working for me without problem:
than:
pip install hg+http://bitbucket.org/pygame/pygame
A.B.
  • 92,125
ThePhi
  • 295
I have found that pygame will not install in a virtualenv on ubuntu 15.10.
The problem is missing links to libswscale and libavformat.
On my system I added the following symlinks:
$ sudo ln -sf /usr/include/x86_64-linux-gnu/libswscale /usr/include/libswscale
$ sudo ln -sf /usr/include/x86_64-linux-gnu/libavformat /usr/include/libavformat
At that point I was able to follow the http://pygame.org/wiki/CompileUbuntu#Installing pygame with pip instructions. I am now levitating in a ball of clear light.
lysdexia
  • 111
For pygame 2 (using SDL 2) with Python 3 on Ubuntu, you need to install the following dependencies (according to CompileUbuntu at pygame.org):
sudo apt-get install --yes libsdl2-dev libsdl2-image-dev libsdl2-mixer-dev libsdl2-ttf-dev libfreetype6-dev python3-setuptools python3-dev python3 libportmidi-dev
Then use pip to install pygame in your venv:
pip install pygame
A complete script could look like this:
$PYTHON_VENV_DIR=.venv
sudo apt-get install --yes python3-venv
all these are required for pygame-2
python3 -m venv $PYTHON_VENV_DIR
source $PYTHON_VENV_DIR/bin/activate
python3 -m pip install --upgrade pip
pip3 install wheel pip3 install pygame
leosh
  • 141
