There is a package (python-pygame) for Python2 available from the universe repository. However, I want to work through the tutorial in the Invent with Python book. Going through SPM (Synaptic), I cannot find a pygame resource for Python3.
Also, I looked on the Pygame website and it is not clear if Pygame is available for Python3 (though the book indicates that it is).
Can someone help me with my dilemma?
6 Answers6
From Pygame wiki:
Does Pygame work with Python 3?
Yes. Pygame 1.9.2 supports Python 3.2 and up. Only the orphaned _movie module (not built by default) does not.
However, there seems no pre-packaged Pygame packages for Python 3 in Ubuntu repositories, at least as of 14.04.
I would suggest you to get the source packages from the pygame website and install it locally into a virtualenv or buildout. Globally installing python modules in evil anyway :) Here are the instructions: http://www.pygame.org/wiki/CompileUbuntu
Alternatively you can try this PPA: https://launchpad.net/~thopiekar/+archive/ubuntu/pygame
Sergey
  • 44,353
Thanks to Sergey's suggestion, this is how to get it working:
INSTALL
(1) Move to a directory where you want the source code to be downloaded to
(2) svn co svn://seul.org/svn/pygame/trunk pygame
    NOTE:  Be sure to use the svn method.  Simply downloading the pygame*.tar.gz
           file from the pygame downloads page didn't work!
(3) cd pygame
(4) python3 config.py
    NOTE:  This confirms that you have the dependencies.
(5) python3 setup.py build
(6) sudo python3 setup.py install
    NOTE:  On my machine, I have the distro's python3.2 installed (which is in
           the /usr/lib directory).  This step places the pygame module into
           /usr/local/lib -- which is what you want (per Sergey's suggestion).
TEST
(1) python3
(2) At the '>>>' prompt, type "import pygame"
    VALIDATION:  If you get another '>>>' prompt, all is well.
per BlaXpirit, you may also choose to use hg instead of svn:
hg clone https://bitbucket.org/pygame/pygame
Someone needs to make a python3-pygame package that does this, but no one has yet
sudo apt-get install mercurial python3-dev python3-numpy libav-tools \
    libsdl-image1.2-dev libsdl-mixer1.2-dev libsdl-ttf2.0-dev libsmpeg-dev \
    libsdl1.2-dev  libportmidi-dev libswscale-dev libavformat-dev libavcodec-dev
cd pygame
Jonathan
  • 3,984
Just use the below command to install pygame for Python3.
pip3 install pygame
It could install pygame correctly on Ubuntu 16.04 and Python Python 3.5.2.
Dagelf
  • 1,476
The pre-requisite packages right now on the Mavproxy wiki will not work with Raspbian :
sudo apt-get install python3-dev python3-opencv python3-wxgtk3.0 python3-pip python3-matplotlib python3-pygame python3-lxml python3-yaml
Instead you will need to use the old one :
sudo apt-get install python-dev python-opencv python-wxgtk3.0 python-pip python-matplotlib python-pygame python-lxml python-yaml
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Thanks again to everyone.
Just did a clean install of Mint 18 Cinnamon 64bit, and was following TheGeek61's post above to get Pygame working again.
But when I tried python3 setup.py build came up with an error:
Traceback (most recent call last):
  File "setup.py", line 109, in <module>
    from setuptools import setup, find_packages
ImportError: No module named 'setuptools'
After some searching, ran the following:
sudo pip install -U setuptools
Which then allowed Pygame for Python3 to install successfully.
Abisdad
  • 1,361
