I'm running Precise Pangolin amd64. I installed Python 3.3 from ppa:fkrull/deadsnakes.
Now I want to actually use this new Python version in a virtualenv. But How can I do this? I get the following error:
$ virtualenv --no-site-packages --distribute -p /usr/bin/python3.3 ~/.virtualenvs/pywork3
Running virtualenv with interpreter /usr/bin/python3.3
The --no-site-packages flag is deprecated; it is now the default behavior.
New python executable in /home2/USERNAME/.virtualenvs/pywork3/bin/python3.3
Also creating executable in /home2/USERNAME/.virtualenvs/pywork3/bin/python
Traceback (most recent call last):
File "/usr/local/lib/python2.7/site-packages/site.py", line 73, in <module>
__boot()
File "/usr/local/lib/python2.7/site-packages/site.py", line 2, in __boot
import sys, imp, os, os.path
ImportError: No module named 'imp'
ERROR: The executable /home2/USERNAME/.virtualenvs/pywork3/bin/python3.3 is not functioning
ERROR: It thinks sys.prefix is '/home2/USERNAME/.virtualenvs' (should be '/home2/USERNAME/.virtualenvs/pywork3')
ERROR: virtualenv is not compatible with this system or executable
If instead, I explicitly use python3.3 to call virtualenv, I get this error:
$ python3.3 /usr/bin/virtualenv --no-site-packages --distribute -p /usr/bin/python3.3 ~/.virtualenvs/pywork3
File "/usr/bin/virtualenv", line 2, in <module>
import virtualenv
ImportError: No module named 'virtualenv'
I'm stuck. Any help is greatly appreciated!
EDIT: Following the advise by @thefourtheye, I purged my local site-packages directory (effectively only deleting site.py). Now I'm getting a step further, but virtualenv complains about a missing easy_install:
Error [Errno 2] No such file or directory:
'/home2/USERNAME/.virtualenvs/pywork3/bin/easy_install' while executing command
/home2/USERNAME/.virt...rk3/bin/easy_install /usr/share/python-virtualenv/pip-1.1.tar.gz
I did install the package python3-setuptools, which installs the Py3 version of easy_install.
EDIT2:
Here's the verbose output, without explicitly passing --distribute and --no-site-packages, as these two switches are default behaviour of my virtualenv:
$ virtualenv --verbose -p /usr/bin/python3.3 ~/.virtualenvs/pywork3
Creating /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3
Symlinking Python bootstrap modules
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/config-3.3m
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/lib-dynload
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/os.py
Ignoring built-in bootstrap module: posix
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/posixpath.py
Cannot import bootstrap module: nt
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/ntpath.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/genericpath.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/fnmatch.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/locale.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/encodings
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/codecs.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/stat.py
Cannot import bootstrap module: UserDict
Cannot import bootstrap module: copy_reg
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/types.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/re.py
Cannot import bootstrap module: sre
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/sre_parse.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/sre_constants.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/sre_compile.py
Ignoring built-in bootstrap module: zlib
Cannot import bootstrap module: _abcoll
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/warnings.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/linecache.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/abc.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/io.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/_weakrefset.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/copyreg.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/tempfile.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/random.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/__future__.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/collections
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/keyword.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/tarfile.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/shutil.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/struct.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/copy.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/base64.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/bisect.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/_dummy_thread.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/hashlib.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/heapq.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/hmac.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/reprlib.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/rlcompleter.py
Symlinking /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/weakref.py
Creating /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/site-packages
Writing /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/site.py
Writing /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/orig-prefix.txt
Writing /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/no-global-site-packages.txt
Creating parent directories for /home2/USERNAME/.virtualenvs/pywork3/include
Symlinking /home2/USERNAME/.virtualenvs/pywork3/include/python3.3m
Creating /home2/USERNAME/.virtualenvs/pywork3/bin
Changed mode of /home2/USERNAME/.virtualenvs/pywork3/bin/python3.3 to 0o755
Changed mode of /home2/USERNAME/.virtualenvs/pywork3/bin/python to 0o755
Testing executable with /home2/USERNAME/.virtualenvs/pywork3/bin/python3.3 -c "
import sys
prefix = sys.prefix
if sys.version_info[0] == 3:
prefix = prefix.encode('utf8')
if hasattr(sys.stdout, 'detach'):
sys.stdout = sys.stdout.detach()
elif hasattr(sys.stdout, 'buffer'):
sys.stdout = sys.stdout.buffer
sys.stdout.write(prefix)
Got sys.prefix result: '/home2/USERNAME/.virtualenvs/pywork3'
Creating /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/distutils
Writing /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/distutils/__init__.py
Writing /home2/USERNAME/.virtualenvs/pywork3/lib/python3.3/distutils/distutils.cfg
Using existing distribute egg: /usr/share/python-virtualenv/distribute-0.6.24.tar.gz
Installing distribute..............................................................................................................................................................................................................................................................................................................................................................................................................done.
Installing existing pip-1.1.tar.gz distribution: /usr/share/python-virtualenv/pip-1.1.tar.gz
Installing pip...
Error [Errno 2] No such file or directory: '/home2/USERNAME/.virtualenvs/pywork3/bin/easy_install' while executing command /home2/USERNAME/.virt...rk3/bin/easy_install /usr/share/python-virtualenv/pip-1.1.tar.gz
...Installing pip...done.
File "/usr/lib/python2.7/dist-packages/virtualenv.py", line 2283, in <module>
main()
File "/usr/lib/python2.7/dist-packages/virtualenv.py", line 938, in main
never_download=options.never_download)
File "/usr/lib/python2.7/dist-packages/virtualenv.py", line 1054, in create_environment
install_pip(py_executable, search_dirs=search_dirs, never_download=never_download)
File "/usr/lib/python2.7/dist-packages/virtualenv.py", line 643, in install_pip
filter_stdout=_filter_setup)
File "/usr/lib/python2.7/dist-packages/virtualenv.py", line 976, in call_subprocess
cwd=cwd, env=env)
File "/usr/lib/python3.3/subprocess.py", line 818, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.3/subprocess.py", line 1416, in _execute_child
raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] No such file or directory: '/home2/USERNAME/.virtualenvs/pywork3/bin/easy_install'
