Hello I upgraded all packages on my Ubuntu, and kernel also. But in upgrading process kernel upgrade failed, and I must always after grub load select older kernel. It is a terminal command to reinstall latest kernel?
Asked
Active
Viewed 6.7k times
33
Run the following command in a terminal (Ctrl+Alt+T):
dpkg -l | grep linux-image-.*-generic
Look for the kernel version you want to reinstall then run:
sudo apt-get install --reinstall linux-image-3.X.Y-ZZ-generic
Of course, you must type the actual kernel version (e.g. linux-image-3.8.0-21-generic) instead of linux-image-3.X.Y-ZZ-generic.
Eric Carvalho
- 55,453
