I have a Dell Inspiron 15 5000 with NVIDIA GeForce MX230.
I upgraded my Ubuntu from 18.04 to 20.04 by means of the graphical updater built-in in the system. During the installation of the packages, the system froze and after many hours of indecision I forced a reboot.
I think the system freeze was somehow related to NVIDIA GPU.
Since then I have faced (and solved) many problems related to this broken system upgrade, however I still have a worrying problem related to the system boot.
Basically, this problem can be faced in two different ways:
- Sometimes the initial Dell splash screen freezes without showing the grub2 choices menu.
- Otherwise, when I choose the Ubuntu system, I get the error:
error: Command failed.
error: you need to load the kernel first.
Press any key to continue...
A trick I use to boot the system is just by restarting it many times until it boots correctly.
To address these booting problems I tried the following:
- Disable secure boot (still disabled)
- Avoid GPU at boot with nomodeset param: https://itsfoss.com/fix-ubuntu-freezing/
- Switch to proprietary NVIDIA drivers:
nvidia-driver-460(proprietary, tested) - Reinstall grub2 and repair boot with Boot-repair: https://help.ubuntu.com/community/Boot-Repair
- Remove outdated snaps: https://superuser.com/questions/1310825/how-to-remove-old-version-of-installed-snaps
- Remove old kernel images: How to easily remove old kernels in Ubuntu 20.04 LTS?.
The output of the following command is:
$ dpkg --list | egrep -i --color 'linux-image|linux-headers|linux-modules' | awk '{ print $2 }'
linux-headers-5.4.0-65
linux-headers-5.4.0-65-generic
linux-image-5.4.0-65-generic
linux-modules-5.4.0-65-generic
linux-modules-extra-5.4.0-65-generic
I thought that something is wrong with partitions at boot, but I was not able to discover more.
The most important partitions of my system are:
$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 7,7G 0 7,7G 0% /dev
/dev/nvme0n1p8 37G 26G 9,4G 73% /
/dev/nvme0n1p1 746M 91M 656M 13% /boot/efi
/dev/nvme0n1p10 148G 131G 9,0G 94% /home
Why do you think I am getting this boot errors? Should I reinstall my system? In this case, how can I do it safely?
