17
I'm running Ubuntu in a VM. How do I disable ntpd?
muru
  • 207,228
To stop ntpd:
sudo /etc/init.d/ntp stop
or
sudo service ntp stop
To prevent it from starting at boot:
sudo update-rc.d -f ntp remove
With systemd, the two commands are:
sudo systemctl stop ntp
sudo systemctl disable ntp
Output (I think the warning can be ignored)
ntp.service is not a native service, redirecting to systemd-sysv-install
Executing /lib/systemd/systemd-sysv-install disable ntp
insserv: warning: current start runlevel(s) (empty) of script `ntp' overrides LSB defaults (2 3 4 5).
insserv: warning: current stop runlevel(s) (1 2 3 4 5) of script `ntp' overrides LSB defaults (1).
Check:
systemctl is-enabled ntp
Output
Executing /lib/systemd/systemd-sysv-install is-enabled ntp
disabled
knb
  • 5,292
Uninstall ntpd if it is installed. You will still have ntpdate installed. (It is difficult to remove.) Prevent it from executing by adding exit 0 to /etc/default/ntpdate.
Update: This is an old answer. Most systems now use systemctl to run commands. To disable ntp and ntpdate issue the commands:
systemctl disable ntp.service
systemctl disable ntpdate.service
You can check the status of ntp related units with the command:
 systemctl list-unit-files | grep ntp
BillThor
  • 4,698
