44
This question shows how to stop automatic time update (and switch to manual):
How to stop automatic time update?
I want to do this exact thing but I can only ssh onto my machine so I need to make this change through the terminal. Is there any way to do this?
GNOME Automatic Date & Time doesn't use the ntp service, installable via sudo apt-get install ntp. Therefore stopping or uninstalling the service doesn't help.
Systemd timedatectl is used, therefore one command to switch off
timedatectl set-ntp 0
and one command to switch on
timedatectl set-ntp 1
Example
% timedatectl set-ntp 1
or via timedatectl status
% timedatectl status
      Local time: Do 2015-10-08 18:17:17 CEST
  Universal time: Do 2015-10-08 16:17:17 UTC
        RTC time: Do 2015-10-08 16:17:17
       Time zone: Europe/Berlin (CEST, +0200)
     NTP enabled: no
NTP synchronized: yes
 RTC in local TZ: no
      DST active: yes
 Last DST change: DST began at
                  So 2015-03-29 01:59:59 CET
                  So 2015-03-29 03:00:00 CEST
 Next DST change: DST ends (the clock jumps one hour backwards) at
                  So 2015-10-25 02:59:59 CEST
                  So 2015-10-25 02:00:00 CET
      Local time: Do 2015-10-08 18:17:35 CEST
  Universal time: Do 2015-10-08 16:17:35 UTC
        RTC time: Do 2015-10-08 16:17:35
     NTP enabled: yes
 RTC in local TZ: no
      DST active: yes
A.B.
  • 92,125
On a systemd operating system like Ubuntu 15.04 use the timedatectl utility, which makes the same Desktop Bus RPC calls as the GNOME control centre utility does:
timedatectl set-ntp false
Further reading
JdeBP
  • 3,979
What you are looking for is not ntpd which is not installed by default. It's an if-up.d script which run time update whenever a network interface activated.
  • dconf watch / shows nothing but inotifywait -m -r /etc/ will do. Here is the interesting output:
    /etc/network/if-up.d/ MOVED_FROM ntpdate
    /etc/network/if-up.d/ MOVED_TO ntpdate.disabled
  • It belongs to ntpdate package.
    $ dpkg -S /etc/network/if-up.d/ntpdate
    ntpdate: /etc/network/if-up.d/ntpdate
  • So to disable time update, rename that file same as the control center does:
    sudo mv /etc/network/if-up.d/ntpdate /etc/network/if-up.d/ntpdate.disabled
user.dz
  • 49,176
