41
I'd like to run a .sh file using bash on logout and shutdown of Ubuntu. I have searched up and down the web and have found only fixes for KDE and GNOME. The script is simple, I just need to know if I can add the line of code to the "logoff/shutdown" file or if I need to reference it in another script.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
How to do it with systemd
If you find this thread after June 2016, Ubuntu and its derivatives including Mint will be using systemd to control system initialization and shutdown. I had problems with the old approach so researched the systemd way.
With systemd you create one or two files to call your scripts using the templates below, and execute a command. Simple.
GUI Version
First create the scripts you want to run at startup and/or shutdown. I created .scopening_atstart and .scfullcopy_atend.
Then make sure that they are both executable by right clicking the file, selecting properties and making sure that, under permissions, you have ticked Allow executing file as a program.
The two files I created populate and save the contents of a ramdisk. They also create a file in my home directory to prove that the service is working. They were of the form:
#!/bin/sh
cp -pru /home/john/zRamdisk/subdirectory1/* /home/john/.wine/drive_c/subdirectory1/
rm /home/john/stop_time
date +%D' '%T > /home/john/stop_time
Then I opened my file manager as root, opened /etc/systemd/system and created a file startup.service and a file save-ramdisk.service. Obviously you can choose your own names and generic names could have included a startup file called johns_start.service and a shutdown file called johns_shutdown.service. Just don't pick existing service names.
[Unit]
Description=Startup Applications
[Service] Type=oneshot RemainAfterExit=false ExecStart=/home/john/.scopening_atstart
[Install] WantedBy=multi-user.target
and
[Unit]
Description=Save Ramdisk to Wine drive C
[Service] Type=oneshot RemainAfterExit=true ExecStart=/bin/true ExecStop=/home/john/.scfullcopy_atend
You can use the same service files, substituting the full path of your executable script for mine.
Finally for each one execute the command systemctl enable your_files_name (but without the suffix service). So my first one was systemctl enable startup
Reboot the computer once to start the services. The start service will be executed whenever systemd enters the multi-user target and the stop service when it exits the multi-user target. Alternative service files with different activation conditions will be described below.
CLI (Command Line) Version
This description assumes that you operate from your home directory rather than /home/john, use sudo as needed, and your choice of editor where I write vim or svim.
Create startup and shutdown shell scripts with the first line #!/bin/sh and make them executable using chmod +x my_new_filename.
Create two files as above, or in this example, one file to handle startup and shutdown tasks. I will execute scripts in my home directory but @don_crissti showed some alternatives at Stack Exchange.
svim /etc/systemd/system/start_and_stop.service
and copy in the file content:
[Unit]
Description=Run Scripts at Start and Stop
[Service] Type=oneshot RemainAfterExit=true ExecStart=/home/john/.startup_commands #your paths and filenames ExecStop=/home/john/.shutdown_commands
Then Enable the Service with the command:
systemctl enable start_and_stop
and reboot your system after which the services will be active. The commands systemctl is-enabled start_and_stop and systemctl is-active start_and_stop can be used in monitoring your new services.
Changing the Trigger Conditions for Shutdown
The files above all use the open or close of the multi-user environment to initiate running the scripts. The file below uses the beginning of four potential shutdown processes to initiate its scripts. Adding or removing the targets on the Before line + the WantedBy line will let you make finer distinctions:
This file was proposed in an answer at Unix & Linux by @Matthias but I was unable to get it to run until I added an Install section.
Again, edit the script in /etc/systemd/service/ and enable it using systemctl enable your_file_name. When I changed the targets I used the systemclt disable file_name command and then re-enabled it which symlinked it to the target directories. Reboot and the service will be operating.
[Unit]
Description=Do something required
DefaultDependencies=no
Before=shutdown.target reboot.target halt.target
# This works because it is installed in the target and will be
#   executed before the target state is entered
# Also consider kexec.target
[Service] Type=oneshot ExecStart=/home/john/.my_script #your path and filename
[Install] WantedBy=halt.target reboot.target shutdown.target
Debugging
I recently (2020) did a little distro hopping, first to KDE Neon where I discovered that although KDE is light on memory, its cpu usage was considerably higher than mint, and then to Fedora 33 XFCE.
With the second, neither of these scripts worked. So I followed the hints and used systemctl status and journalctl -xe to find the issues. It turned out that something didn't have permission to run the scripts in my home directory. I experimented unsuccessfully until I changed the invocation to:
ExecStart=/usr/bin/bash /home/john/.scopening_atstart
This may help someone; but be aware that your system may be using /bin/bash so check your file names and paths.
John 9631
  • 877
21
To execute a script upon logout:
  1. Add the following line in /etc/lightdm/lightdm.conf file:
    session-cleanup-script=/path/to/script
  2. You have to restart LightDM in order for this change to take effect. To do this go in TTY1 using Ctrl+Alt+F1, login with your username and password and run the following command:
    sudo service lightdm restart
  • Note: use Ctrl+Alt+F7 to switch to the graphical session.
To execute a script upon reboot:
  1. Put your script in /etc/rc0.d.
  2. Make it executable:
    sudo chmod +x K99_script
  • Notes:
    • The scripts in this directory are executed in alphabetical order.
    • The name of your script must begin with K99 to run at the right time.
To execute a script at shutdown:
  1. Put your script in /etc/rc6.d.
  • Notes:
Sources:
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
