I want to run a script at shutdown, and a far as I can tell I've followed the proper procedures. The script (close) is supposed to launch another script (gdrive) in a terminal which prompts me to sync my Google drive folder.
Here's what I've done:
  1. Copied files "close" and and "gdrive" into /etc/init.d and made them executable.
  2. Then I run the command update-rc.d close start 0 0 . from the command line. As expected this creates a link in /etc/rc0.d called S00close which points to the file close. Manually testing this link from the command line runs close, launches gdrive in a terminal and generally behaves as expected.
Unfortunately, nothing happens when I shutdown my machine.
Here is the code from close. In the first line I delay shutdown because I think the sync will take about 5 minutes or so:
#!/bin/sh
echo "PASSWORD" | sudo -S shutdown -c
xterm -e '/etc/init.d/gdrive'
Here is the code from gdrive (although, close doesn't run on shutdown, so I'm not sure how relevant this is):
#!/bin/sh
echo "Sync Gdrive?"
read response
if [ $response = "y" ]; then
cd ~/Gdrive
drive push -ignore-name-clashes -quiet -ignore-conflict
drive pull -ignore-name-clashes -quiet -ignore-conflict
echo "Drive successfully synced"
echo "PASSWORD" | sudo -S shutdown -h now
exit 1
else
echo "Ok, maybe next time"
exit 1
fi
I'm not super knowledgeable with this stuff, so any advice is appreciated. Even if someone could tell me how I can see what is happening at shutdown (what log files to look at etc.) that would be great.
terdon
  • 104,119
OP has solved the problem:
Thanks for replying. I have re-evaluated my strategy a little. I've just put a button in my launcher that runs the second script. This is much simpler and accomplishes the same thing.
A.B.
  • 92,125
