In BackInTime I'm using couple different DBus methods to work on all major DEs. Only downside is this won't work for root because root has no dbus.SessionBus.
#!/usr/bin/env python3
import sys
import dbus
from time import sleep
INHIBIT_LOGGING_OUT = 1
INHIBIT_USER_SWITCHING = 2
INHIBIT_SUSPENDING = 4
INHIBIT_IDLE = 8
INHIBIT_DBUS = (
{'service': 'org.gnome.SessionManager',
'objectPath': '/org/gnome/SessionManager',
'methodSet': 'Inhibit',
'methodUnSet': 'Uninhibit',
'interface': 'org.gnome.SessionManager',
'arguments': (0, 1, 2, 3)
{'service': 'org.mate.SessionManager',
'objectPath': '/org/mate/SessionManager',
'interface': 'org.mate.SessionManager',
{'service': 'org.freedesktop.PowerManagement',
'objectPath': '/org/freedesktop/PowerManagement/Inhibit',
'methodUnSet': 'UnInhibit',
'interface': 'org.freedesktop.PowerManagement.Inhibit',
'arguments': (0, 2)
def inhibitSuspend(app_id = sys.argv[0],
toplevel_xid = None,
reason = 'take snapshot',
flags = INHIBIT_SUSPENDING | INHIBIT_IDLE):
Prevent machine to go to suspend or hibernate.
Returns the inhibit cookie which is used to end the inhibitor.
if not app_id:
app_id = 'backintime'
if not toplevel_xid:
toplevel_xid = 0
for dbus_props in INHIBIT_DBUS:
try:
bus = dbus.SessionBus()
interface = bus.get_object(dbus_props['service'], dbus_props['objectPath'])
proxy = interface.get_dbus_method(dbus_props['methodSet'], dbus_props['interface'])
cookie = proxy(*[(app_id, dbus.UInt32(toplevel_xid), reason, dbus.UInt32(flags))[i] for i in dbus_props['arguments']])
print('Inhibit Suspend started. Reason: %s' % reason)
return (cookie, bus, dbus_props)
except dbus.exceptions.DBusException:
pass
print('Inhibit Suspend failed.')
def unInhibitSuspend(cookie, bus, dbus_props):
Release inhibit.
assert isinstance(cookie, int), 'cookie is not int type: %s' % cookie
assert isinstance(bus, dbus.bus.BusConnection), 'bus is not dbus.bus.BusConnection type: %s' % bus
assert isinstance(dbus_props, dict), 'dbus_props is not dict type: %s' % dbus_props
try:
proxy = interface.get_dbus_method(dbus_props['methodUnSet'], dbus_props['interface'])
proxy(cookie)
print('Release inhibit Suspend')
return None
print('Release inhibit Suspend failed.')
if __name__ == '__main__':
cookie, bus, dbus_props = inhibitSuspend()
print('do something here')
sleep(10)
