15
I failed to upgrade MySQL server. Here's what I tried:
I first issue this command to update the package list:
sudo apt-get update
Then, upgrade by:
sudo apt-get upgrade
It shows the following error:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 mysql-server-5.5 : Depends: mysql-server-core-5.5 (= 5.5.28-0ubuntu0.12.04.2) but 5.5.31-0ubuntu0.12.04.1 is installed
E: Unmet dependencies. Try using -f.
Apparently a newer version is installed (but why? I didn't install manually). Okay, As it suggests, I issue the command to attempt fixing:
sudo apt-get -f install
Here is the output:
Correcting dependencies... Done
The following extra packages will be installed:
  mysql-server mysql-server-5.5
Suggested packages:
  tinyca mailx
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
2 not fully installed or removed.
Need to get 0 B/8889 kB of archives.
After this operation, 64.5 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LC_CTYPE = "UTF-8",
    LANG = "en_HK.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
dpkg: dependency problems prevent configuration of mysql-server-5.5:
 mysql-server-5.5 depends on mysql-server-core-5.5 (= 5.5.28-0ubuntu0.12.04.2); however:
  Version of mysql-server-core-5.5 on system is 5.5.31-0ubuntu0.12.04.1.
dpkg: error processing mysql-server-5.5 (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
                          dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.5; however:
  Package mysql-server-5.5 is not configured yet.
dpkg: error processing mysql-server (--configure):
 mysql-server-5.5
 mysql-server
Then I try to use another command that some people suggest in the Internet:
sudo apt-get -f upgrade
Same output is produced. Apart from re-installing MySQL server, what else can I do ?
using Ubuntu server 12.04 LTS
Braiam
  • 69,112
Raptor
  • 431
That happened to me but it was that, after doing a sudo apt-get update it somehow did not get the newest version of the mysql-server, only of the mysql-server-core. I would first suggest to do another sudo apt-get update and then proceed on installing the package
sudo apt-get install mysql-server
If that does not work then do a reinstall:
sudo apt-get install --reinstall mysql-server
And if that does not work, then simply purge the package mysql-server-core package, then install mysql-server again.
sudo apt-get purge mysql-server-core mysql-server-core-5.5
And if that does not work then go crazy on it with:
sudo apt-get clean
sudo apt-get autoclean
sudo apt-get purge mysql-server*
As a last resort, I would purge, reboot, install.
Luis Alvarado
  • 216,643
