I am running the following on 23.10 on 7th May 2024.
sudo apt-get install mysql-server
[sudo] password for USER:
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies.
mysql-common : Conflicts: mysql-server-8.0 but 8.0.36-0ubuntu0.23.10.1 is to be installed
mysql-server-8.0 : Depends: mysql-client-8.0 (>= 8.0.36-0ubuntu0.23.10.1) but it is not installable
Depends: mysql-server-core-8.0 (= 8.0.36-0ubuntu0.23.10.1) but it is not installable
As can be seen it looks like there isn't a MYSQL version available for my Ubuntu version at this time. I have run the advice on answers such as this - Upgrade MySQL server issue which purge MySQL and reinstall but the error remains the same.
Q) Is there a way of installing mysql from a more reliable place / way so that its not quite as tied to the Ubuntu version or should I simply wait a few days and see if it works?
