When I start the Ubuntu software centre, it says I cannot do anything until the package catalog is repaired. However, repairing fails.
I ran sudo apt-get -f install and found the problem to be:
mysql-server-5.5 depends on mysql-server-core-5.5 (= 5.5.24-0ubuntu0.12.04.1); however:
  Version of mysql-server-core-5.5 on system is 5.5.28-0ubuntu0.12.04.2.
So, the question is, how do I install that version and resolve the dependency problem?
Braiam
  • 69,112
Tama
  • 59
Since I didn't actually need MySQL server anymore I solved this by uninstalling programs with unresolved dependencies one by one.
First I had a similar error:
mysql-server-5.5 : Depends: mysql-server-core-5.5 (= 5.5.29-0ubuntu0.12.04.1)
  but 5.5.29-0ubuntu0.12.04.2 is to be installed
I uninstalled mysql-server-core-5.5 using dpkg:
$ sudo dpkg --remove mysql-server-core-5.5
The another error arised:
mysql-server-5.5 : Depends: mysql-server-core-5.5 (= 5.5.29-0ubuntu0.12.04.2)
  but it is not going to be installed
Uninstall mysql-server-5.5 this time:
$ sudo dpkg --remove mysql-server-5.5
One step higher in the hierarchy:
mysql-server : Depends: mysql-server-5.5 but it is not going to be installed
Uninstall mysql-server:
Seems to work now.
Iulius Curt
  • 173
First make sure your package sources are correct. Then run a
sudo apt-get update
just to make sure. If that still doesn't work then continue on.
Remove the offending package
sudo dpkg --remove 5.5.28-0ubuntu0.12.04.2
folowed by
This should remove MySQL completely (including the meta packages you stated).
You can then re-install with:
sudo apt-get install mysql-server-5.5
coteyr
  • 18,724
I had the same problem with mysql-server-core-5.5 version 5.5.29-0ubuntu0.12.04.1
mysql-server-5.5 depende de mysql-server-core-5.5 (= 5.5.24-0ubuntu0.12.04.1); sin embargo: La versión de `mysql-server-core-5.5' en el sistema es 5.5.29-0ubuntu0.12.04.1
I solved it with this commands:
  1. Backup de database(s)
  2. Check all version avaible of mysql-server for you linux distribution. sudo apt-cache madison mysql-server-5.5.
  3. Remove the packages of mysql-server. sudo apt-get remove mysql-server-5.5 mysql-server-core-5.5.
  4. Install a old version (see the second point for select one). And run the command: sudo apt-get install mysql-server-5.5=5.5.22-0ubuntu1 mysql-server-core-5.5=5.5.22-0ubuntu1
