25
I am trying to install opera browser from the terminal. I downloaded the 'debian' installer because it didn't show up in software center.
It completely destroyed my software center - it is frozen and I have no idea how to fix (I have a different thread for that though).
Can I use this thing called synaptic package manager to install Opera? or am I stuck with Firefox?
How do I install Opera Browser?
bruce
  • 2,977
5 Answers5
25
How to install Opera on Ubuntu:
From the terminal, add a pointer to the opera stable sources:
sudo sh -c 'echo "deb http://deb.opera.com/opera/ stable non-free" >> /etc/apt/sources.list.d/opera.list'
Install the key:
sudo sh -c 'wget -O - http://deb.opera.com/archive.key | apt-key add -'
Update repo:
sudo apt-get update
Install Opera:
sudo apt-get install opera
Synaptic is a graphical interface for Aptitude, the package manager in Ubuntu/Linux. It provides a listing of available software packages that are available to download and install from the repositories listed in your Software Sources. Synaptic is less intimidating to use than apt-get in a Terminal interface for users not used to dealing with the command line.
Preceding commands in Terminal/command line with sudo imparts a restricted root-user ability for performing commands that are not available for standard user accounts.
When in doubt about any basic command in Terminal, you can always man [base command] to access the command manual pages. man sudo will show the manual for sudo, for example. There is also extensive documentation on the Ubuntu website for most commands.
As for installing Opera, it is not maintained in the standard Ubuntu repositories. You have two options:
1) add the Opera repository to your Software Sources as mentioned in the other answer and following the directions in the provided link; or
2) download and install Opera manually.
To install Opera manually, go to the Opera website (www.opera.com) and download it from there. Presuming that you have your downloads set to go to your Downloads Folder, you can run the following in Terminal:
cd /home/your_account/Downloads ;ls -l Replace "your_account" with your short name; the "ls -l" will list the contents of the Downloads folder. Locate the Opera package file - it should be something like 'Opera_12.15.1748_amd64.deb'.
sudo dpkg -i Opera_12.15.1748_amd64.deb and enter your password when prompted. This will run the Opera installer.
In order to have Opera updated automatically, you should still add the Opera repository to your list of software sources.
douggro
  • 2,587
Opera is available as a snap package in all currently supported versions of Ubuntu. To install Opera open the terminal and type:
sudo snap install opera
Opera web browser comes with built-in ad blocker, battery saver, free Aria AI chatbot and free VPN.
karel
  • 122,292
  • 133
  • 301
  • 332
By the time this question was answered, things have evolved.
By now, you can simply go to Download Opera browser, then click the button above Opera for Windows, Mac or Linux and the website will detect your operating system and processor architecture (32 or 64 bits) using device fingerprinting and prompt you a .deb package to download and install by a simple click using the Ubuntu Software Center.
Update (09/12/2017):
I just tested this again on 2 different virtual machines (Ubuntu 16.04 and 17.04 LTS), and the procedure worked as described above.
Open Terminal ( Ctrl + Alt + T).
Import the public signing key for Opera
wget -qO- https://deb.opera.com/archive.key | sudo apt-key add -
Run the following command to add Opera browser repository to the system.
echo "deb https://deb.opera.com/opera-stable/ stable non-free" | sudo tee /etc/apt/sources.list.d/opera-stable.list
Update the repository index.
sudo apt-get update
Install the Opera browser using the apt command.
sudo apt-get install -y opera-stable
While installing Opera, the installer will ask you to set up Opera repository for easy upgrade of Opera browser by which you can easily upgrade Opera during the regular system upgrades. Choose Yes and press enter.
Access Opera Browser as follows: Go to Activities >> Search for Opera.
