I use Ubuntu 12.04. Today I tried to burn an ISO file in a DVD-R disk using K3b. It used to work, but today, after one and a half minutes, it stopped saying that "cdrecord has no permission to open the device". I searched for a solution, and I found that I had to do something with k3bsetup. I tried to use it, but I had no idea what to do, and I couldn't find a guide, so I checked cdrecord and clicked apply. Now there is another error; it says "cdrecord returns an unknown error! (code 254)". What should I do?
Asked
Active
Viewed 1.9k times
I had similar problem and fixed it with the following steps:
- Open k3b.
- Go to Settings -> Setup system Permissions.
- Select all options and apply.
It will ask for your password (you must be admin).
If it doesn't works, open k3b from terminal with sudo -H k3b, and try same steps as before.
Should help.
Eliah Kagan
- 119,640
pablodav
- 353
This solve the problem:
cd /usr/bin/
sudo chmod 0755 cdrdao
sudo chmod a+s cdrdao
sudo chown root:root cdrdao
sudo chmod 0755 wodim
sudo chmod a+s wodim
sudo chown root:root wodim
MaxV
- 189
