-1
Even if it is seen into drives my system won't recognize the writer... since 15.04 update...
With k3b started as root the problem stays the same
system configuration problem even if seeing into drives
Dont understand why I cannot write, is there a driver change on last kernel?
sudo cat /proc/sys/dev/cdrom/info
CD-ROM information, Id: cdrom.c 3.20 2003/12/17
drive name:             sr0
drive speed:            24
drive # of slots:       1
Can close tray:         1
Can open tray:          1
Can lock tray:          1
Can change speed:       1
Can select disk:        0
Can read multisession:  1
Can read MCN:           1
Reports media changed:  1
Can play audio:         1
Can write CD-R:         0
Can write CD-RW:        0
Can read DVD:           1
Can write DVD-R:        0
Can write DVD-RAM:      0
Can read MRW:           1
Can write MRW:          1
Can write RAM:          1
you need to be in the "burn" group of your operating system...
you can do this through the wizanrd in k3b below "settings -> system settings"
Mr.Gosh
  • 463
