49
How to delay a program such as cairo-dock (No openGL) or Firefox?
Sometimes programs crash when started with other startup apps. I want programs to start 10 seconds late to avoid a crash.
MERose
  • 437
  • 24
6 Answers6
60
Delaying autostart with inbuilt delay option
Note: Only works with desktop sessions that recognize the X-GNOME-Autostart-Delayparameter (e.g. Unity, Unity2D, GNOME). This will not work for LXDE, XFCE, KDE, etc.
With this solution there's no need for a script or sleep. Head to your autostart folder:
nautilus ~/.config/autostart
Find the .desktop file that corresponds with your application and open it in a text editor, e.g. gedit:
gedit ~/.config/autostart/application.desktop
Append the following line to the file:
X-GNOME-Autostart-Delay=foo
where foo is the time in seconds you want to delay the application launch by, e.g.:
X-GNOME-Autostart-Delay=60
Save the file, relog and you should see the effects.
noraj
  • 831
Glutanimate
  • 21,763
28
Try this:
bash -c "sleep 10 && firefox"
pomsky
  • 70,557
lukasz
  • 2,436
You could try to change the command to this:
sleep 10 && firefox
Some people say it works, some say it doesn't, if this is your case, and it does not work, you can try with:
xterm -e 'sleep 10 && firefox'
sebikul
  • 1,933
I had to use this to get it to work for skype: sh -c "sleep 10 && skype &" in Ubuntu 12.04
Anwar
  • 77,855
Shaun
  • 73
Make a startup command using https://askubuntu.com/a/48327/139749 . Then you can add delay by opening ~/.config/autostart and edit related file. You should add the following commands:
X-GNOME-Autostart-enabled=true
X-GNOME-Autostart-Delay=10
Huseyin
  • 802
Solution by @Noraj works well for Ubuntu 18.04. Adding a couple of practical examples for Google Drive sync via Insync, and Synology cloud-drive. I don't want them to delay the startup.
For google-drive:
[Desktop Entry]
Version=1.0
Type=Application
Name=Insync
GenericName=Insync
Comment=Launch Insync
Icon=insync
Categories=Network;
Exec=insync start
TryExec=insync
Terminal=false
And for cloud-drive:
[Desktop Entry]
Name=Synology Drive Client
Comment=Synology Drive Client
Exec=synology-drive autostart
Icon=/opt/Synology/SynologyDrive/images/ico_72_cloud_station.png
Terminal=false
Type=Application
Categories=Network;FileTransfer;
X-GNOME-Autostart-Delay=75
Both files locate at $HOME/.config/autostart if you installed the applications and chose to make them start at login.
f0nzie
  • 171
