18
On startup, Dropbox runs files indexing, which brings the system pretty much to a stand still for three minutes.
Is there a way to restrict Dropbox from accessing the hard disk, or decrease the priority of Dropbox's access to the hard disk?
aiao
  • 348
5 Answers5
13
Complementing the answer of Carlos D. Barranco, you can edit the launcher file located in /usr/share/applications/dropbox.desktop and permanently set a low priority start for dropbox.
In my case, it was also useful to limit the processor usage of dropbox. You can install package cpulimit: # apt-get install cpulimit
For example, to limit dropbox up to 20% processor usage: # cpulimit -b -e dropbox -l 20
In order to configure both low IO and low processing for dropbox automatically with the system launch, edit /usr/share/applications/dropbox.desktop and replace dropbox start -i by ionice -c 3 dropbox start -i && cpulimit -b -e dropbox -l 20
Command ionice will set idle priority for IO access and the parameter -l of cpulimit configures the processing limit in percentual values. More information on cpulimit can be found in: http://www.nixtutor.com/linux/changing-priority-on-linux-processes/
The right command is the following:
But you have to be careful and deactivate dropbox check box "Start dropbox on system startup" in dropbox config. Otherwise, dropbox will restore the command in the config file to "dropbox start -i" (without ionice call).
Hope this helps.
qbi
  • 19,515
Running Kubuntu 14.04, the above suggestions did not work. I came up with this one and it solved this problem for me on my Lenovo T510.
In the file /usr/share/applications/dropbox.desktop, change the Exec line to read:
Exec=ionice -c 2 -n 7 dropbox start -i
Watching iotop, dropbox gets 99% of the CPU ONLY when no other process wants some time. It shares the hard drive with other processes by lowering it's demand level.
muru
  • 207,228
You propably have encrypted home directory? Decrypting all the files on your Dropbox folder takes time and all your CPU capacity (I have the same problem). Switching dropbox process to low priority has the desired effect of un-jamming the computer and syncing still working fine.
I just don't know how to automatically always start Dropbox with lower prioirty.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Grin
Maybe a complex solution, but it should work and resolve your problem:
Setup a file system in your system’s memory (tmpfs) and set that as your Dropbox folder. (Anything under /run/ will do this automatically.) It is temporary and will be deleted when you reboot! So you should setup something like a cron-job to periodically synchronize this location to a persistent folder in your home folder.
Update: This article disuses this method for browser profiles.
Alternatively, ionice will let you set the process priority to the file system. It could actually be more complicated to maintain and I am not even sure it does what you want.
Daniel
  • 1,288
