49
Where can I send feature requests? Both for Ubuntu as a whole and individual (supported) apps?
janot
  • 1,790
Noel
  • 1,862
You can make a feature suggest by submitting it as a "bug" at bugs.launchpad.net/ubuntu.
Mark the bug starting with wishlist: and the developers will know there is a demand. Only the maintainer of a project or bug superviser can then change the "Importance" to "Wishlist"
These types of bugs unfortunately are not usually given a high priority so you may have more luck trying to approach the upstream developers.
The link to actually file a bug "Report a bug" in the top right corner leads to a page, where the possibility to file a bug is hard to find. The link can be found in the section:
3. Tips and tricks >> 2. Filing bugs at Launchpad.net
It is also possible to file a bug now at the console if you type
ubuntu-bug
into the console and follow the instructions.
Note: I think this whole process could be optimized and I think it is strange to call feature requests still "bugs".
So I filed a feature-request here
rubo77
  • 34,024
  • 52
  • 172
  • 299
17
Individual Applications
For individual apps, the best way is filing a bug requests or feature request in the individual applications.
Some upstream development portals might be having explicit feature for asking user ideas but most of them use their bug tracker for that.
Example, you want a new feature in Synapse (the kick-ass launcher powered by zeitgeist) then you can file a bug request, ask for the feature and ask for the bug to be classified under [Wishlist].
Or before filing bugs for wishlist, you might want to talk to the devs of the particular application. You can look at their mailing list or IRC channel.
Jorge Castro
  • 73,717
Manish Sinha
  • 11,671
To report bugs or do feature requests to Ubuntu:
1. For individual applications:
Figure out how to file a bug or feature request for that individual application.
Ex: after a series of searches and clicking around I discovered that all GNOME-related bugs and feature requests should be submitted to the GNOME-project directly. This includes for gnome-terminal, for instance. Do that on GitLab here: https://gitlab.gnome.org/GNOME.
2. For Ubuntu itself, or in the case that the individual application tells you to file the bug or feature request "with your Linux distribution's maintainers":
Here are the answers for Ubuntu itself:
  1. Read here: https://help.ubuntu.com/community/ReportingBugs.
    Holy smokes, that's long! Whew, what's the short answer?
  2. To report bugs, type ubuntu-bug into your terminal and follow the instructions.
  3. To do a feature request:
    1. Post it on Launchpad here: https://bugs.launchpad.net/ubuntu/+filebug/?no-redirect Update: Sebastien Bacher tells me to post it on https://discourse.ubuntu.com/ instead.
    2. AND/OR email the Ubuntu-devel-discuss group at ubuntu-devel-discuss@lists.ubuntu.com. However, if you're not part of the group, your email will probably be rejected, so first sign up here: https://lists.ubuntu.com/mailman/listinfo/ubuntu-devel-discuss. And then when you go to send the email, be sure to send it from the same email you just signed up with.
Note that I found this Launchpad link to manually report bugs or feature requests buried way down on this page here under the section titled "Filing bugs manually at Launchpad.net", and the words "Launchpad's own bug report form".
Feature requests I've done:
  1. I'd like to see Nemo become the default file manager instead of Nautilus:
    1. https://bugs.launchpad.net/ubuntu/+source/nautilus/+bug/1885170
    2. How to set Nemo as the default file manager in Ubuntu 18.04?
  2. I'd like to see gnome-terminal add the ability to split the screen easily, like terminator: https://gitlab.gnome.org/GNOME/gnome-terminal/-/issues/280
  3. I'd like an easy way to script the opening of tabs in gnome-terminal: https://gitlab.gnome.org/GNOME/gnome-terminal/-/issues/281, rather than doing my pretty ridiculous (but perfectly-functional) work-around I describe here: Open Terminal with multiple tabs and execute application.
Gabriel Staples
  • 11,502
  • 14
  • 97
  • 142
According to Ubuntu Documentation feature requests should be submitted to ubuntu-devel-discuss mailing list.
janot
  • 1,790
