28
What can I do to run automatically a script after I mount/plugin or unmount/unplug a USB device?
Sadi
  • 11,074
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Thanks to MinimusHeximus and the respective contributors to the thread he mentioned in his comment to my similar question, I think I can now offer you the following answer.
You'll need 5 (five) files for such a USB device as follows, simply filling in respective values <fortheseparts>:
/etc/udev/rules.d/00-usb-<yourdevice>.rules
ACTION=="add", ATTRS{idVendor}=="<yourvendorid>", ATTRS{idProduct}=="<yourproductid>", ENV{XAUTHORITY}="/home/<user>/.Xauthority", ENV{DISPLAY}=":0", OWNER="<user>", RUN+="/usr/local/bin/usb-<yourdevice>-in_udev"
ACTION=="remove", ATTRS{idVendor}=="<yourvendorid>", ATTRS{idProduct}=="<yourproductid>", ENV{XAUTHORITY}="/home/<user>/.Xauthority", ENV{DISPLAY}=":0", OWNER="<user>", RUN+="/usr/local/bin/usb-<yourdevice>-out_udev"
#!/bin/bash
/usr/local/bin/usb-<yourdevice>-in &
#!/bin/bash
sleep 1
<yourbashscriptcode>
#!/bin/bash
/usr/local/bin/usb-<yourdevice>-out &
#!/bin/bash
sleep 1
Notes:
  1. You can capture the values <yourvendorid> and <yourproductid> by entering the command lsusb in Terminal -- when your USB device is plugged in -- which will list all your USB devices currently available, like Bus 003 Device 002: ID 8087:07da Intel Corp., where 8087 is the VendorID and 07da is the ProductID.
  2. And <yourdevice> can be any arbitrary name you may choose for your USB device, for example, I chose to use the generic name "keyboard" when creating such files for my USB keyboard which required applying a different keyboard layout whenever it's plugged in.
  3. In some scenarios, it may not be necessary to use the ACTION=="remove" line in the udev rules file, and hence the associated 2 (two) "out" files, when you don't need to do anything (e.g. reverse a change made when the device is plugged in) after the device is plugged out.
  4. Some display managers store the .Xauthority outside the user home directory. You will need to update the ENV{XAUTHORITY} accordingly. As an example GNOME Display Manager looks as follows:
    $ printenv XAUTHORITY
    /run/user/1000/gdm/Xauthority
abrac
  • 210
Sadi
  • 11,074
The file manager SpaceFM allows that. See Auto Run settings, for example Auto Run | On Mount or Auto Run | On Unmount.
jep
  • 448
