Just to let you know: If you have cuesheets to those files you can split them by the information provided by the cuesheet file.
I don't know about GUI tools for this job, but I used mp3splt for such a task in the past. You could convert all those files into MP3 or Vorbis (oggsplt) and then feed them to mp3splt.
Here is an example:
$ mp3splt -rS 5 hoaxcast122_versailles.mp3
mp3splt 2.4.2 (13/05/12) - using libmp3splt 0.7.2
Matteo Trotta <mtrotta AT users.sourceforge.net>
Alexandru Munteanu <io_fx AT yahoo.fr>
THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!
Processing file 'hoaxcast122_versailles.mp3' ...
info: file matches the plugin 'mp3 (libmad)'
info: found Xing or Info header. Switching to frame mode...
info: MPEG 1 Layer 3 - 44100 Hz - Mono - FRAME MODE - Total time: 41m.01s
info: starting 'split in equal tracks' mode
File "hoaxcast122_versailles_00m_00s__08m_12s_39h.mp3" created
File "hoaxcast122_versailles_08m_12s_39h__16m_24s_78h.mp3" created
File "hoaxcast122_versailles_16m_24s_78h__24m_37s_17h.mp3" created
File "hoaxcast122_versailles_24m_37s_17h__32m_49s_56h.mp3" created
File "hoaxcast122_versailles_32m_49s_56h__41m_01s_94h.mp3" created
Processed 94247 frames - Sync errors: 0
split in equal tracks ok
The parameter r stands for trim using silence detection and S stands for split into equal time tracks or better said parts (5 in this case, which would result in 10 minutes per file in your case).
You could create a project folder containing the converted mp3 files and run the following bash script to have all .mp3 files split with the command:
for file in $(ls *.mp3); do mp3splt -rS 5 $file; done
As far as I know the files are not re-encoded, just split and re-wrapped into proper container.
