10
W: Failed to fetch http://dl.google.com/linux/deb/dists/raring/Release.gpg  Something wicked happened resolving 'dl.google.com:http' (-11 - System error)
W: Failed to fetch http://packages.medibuntu.org/dists/raring/Release.gpg  Something wicked happened resolving 'packages.medibuntu.org:http' (-11 - System error)
W: Failed to fetch http://repository.spotify.com/dists/raring/non-free/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://repository.spotify.com/dists/raring/non-free/binary-i386/Packages  404  Not Found
W: Failed to fetch http://dl.google.com/linux/deb/dists/raring/non-free/binary-amd64/Packages  404  Not Found [IP: 173.194.46.69 80]
W: Failed to fetch http://dl.google.com/linux/deb/dists/raring/main/binary-amd64/Packages  404  Not Found [IP: 173.194.46.69 80]
W: Failed to fetch http://dl.google.com/linux/deb/dists/raring/non-free/binary-i386/Packages  404  Not Found [IP: 173.194.46.69 80]
W: Failed to fetch http://dl.google.com/linux/deb/dists/raring/main/binary-i386/Packages  404  Not Found [IP: 173.194.46.69 80]
W: Failed to fetch http://ppa.launchpad.net/stebbins/handbrake-releases/ubuntu/dists/raring/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/stebbins/handbrake-releases/ubuntu/dists/raring/main/binary-i386/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/amith/ubuntutools/ubuntu/dists/raring/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/amith/ubuntutools/ubuntu/dists/raring/main/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old`
How can I fix this? It happens every time i run sudo apt-get update?
david6
  • 14,528
  • 38
  • 46
chad
  • 965
Most of your PPA are outdated or doesn't exist anymore. For example the last one "http://ppa.launchpad.net/amith/ubuntutools/ubuntu/dists/raring/main/binary-i386/Packages" should be replaced with "http://ppa.launchpad.net/amith/ubuntutools/ubuntu/dists/quantal/main/binary-i386/Packages".
Look at your /etc/sources.list (or the files in /etc/sources.list.d) and remove or fix those lines that cause the error.
UPDATE:
The answer here should help.
0x0
  • 636
This is a non-standard configuration, and you attempting to get updates (for Ubuntu) from dl.google.com (the Google download servers).
Why are you using this setup?
This is likely a temporary condition, but you need to be asking Google (forums) how to resolve.
david6
  • 14,528
  • 38
  • 46
