I have a multimedia keyboard that allows me to easily mute the sound (Ubuntu 12.04). It would be nice to "link" this to also turn off libnotify messages that pop-up in the top right corner (i.e. Pidgin messages).
So when Ubuntu is muted, no libnotify messages would pop up. When not muted, messages show as normal.
Is this possible with a script of some kind or would it require changing source code?
It would require changing the source code of notify-osd to turn off all notifications (or at least, to filter some; you may want to keep the sound/brightness/etc… notifications active for example, or urgent ones).
Outside of changing the source code of notify-osd (the daemon which runs in the user session and handles the display of the notifications), there is no way to disable all notifications like this.
dobey
  • 41,650
See my script on github.
This answer includes a script to toggle notify-osd notifications on Ubuntu 12.04, and shows how to bind it to a keyboard shortcut.
Related:
I'd try two approaches if I needed this facility.
Option 1:
Bind the key that does the mute to a script. This is a simple approach and removes any complication of knowing the inards of libnotify
Option 2:
Run a cron job that runs every second to interrogate the state of pulse audio and then disable or enable libnotify. I haven't given you detailed instructions, but sometimes some ideas can get you on the right track. I have done neither of these so I can't give you a step by step but the concepts are not out of the realm of impossibility.
By the way its a great idea! I will stick it on my things to do one I get the time as it's a great idea :)
